Forced upgrade every week
  1. I have upgraded to the lates release 10.8.0 (from 10.4.0)
  2. The instance is running without problems
  3. Once a week (usually Tue) the server is blocked and an upgrade is required
No upgrade is required.
The upgrade is forced and I have to run sudo -u www-data php occ upgrade via CLI or web.
Message from the system cron:
ownCloud or one of the apps require upgrade - only a limited number of commands are available You may use your browser or the occ upgrade command to do the upgrade Update required, skipping cron
Operating system: Ubuntu 20.04.2 LTS
Web server: Apache 2.4.41
Database: MySQL 8.0.26
PHP version: 7.4.3
ownCloud version: 10.8.0
I assume the logs should tell you, which app triggered the update.
mochour,
It is possible that you have run into the upgrade loop bug. The devs are working on it, see [QA] occ upgrade does nothing, although web-ui says 'Update needed' · Issue #38549 · owncloud/core · GitHub
If you have got duplicate apps in your apps/apps-external folder have a look at Update needed and nobody - #2 by cortho how to temporarily fix your issue.
Here is content of the log. Can you see which application required upgrade?
{“reqId”:“YROxXZMmSt08cvBWt0bK@QAAAAQ”,“level”:3,“time”:“11.08.2021 13:15:42”,“remoteAddr”:“2a01:9420:93:555:1168:b5eb:6a6c:d181”,“user”:“–”,“app”:“index”,“method”:“GET”,“url”:“/owncloud/index.php/core/js/oc.js?v=e39bf1e5c457f35f0280c9484a4eb75a”,“message”:“Exception: {"Exception":"OC\\NeedsUpdateException","Message":"","Code":0,"Trace":"#0 \/var\/www\/owncloud\/lib\/private\/legacy\/app.php(125): OC_App::loadApp()\n#1 \/var\/www\/owncloud\/lib\/private\/legacy\/util.php(150): OC_App::loadApps()\n#2 \/var\/www\/owncloud\/lib\/base.php(926): OC_Util::setupFS()\n#3 \/var\/www\/owncloud\/index.php(54): OC::handleRequest()\n#4 {main}","File":"\/var\/www\/owncloud\/lib\/private\/legacy\/app.php","Line":189}”}
{“reqId”:“YROxYVlLOH9UzRg67-ccwQAAAAU”,“level”:0,“time”:“11.08.2021 13:15:45”,“remoteAddr”:“2a01:9420:93:555:1168:b5eb:6a6c:d181”,“user”:“–”,“app”:“core”,“method”:“GET”,“url”:“/owncloud/core/ajax/update.php?requesttoken=NmpKM1shNhkVHwIFIyAxHQsXTAYNBSg8TD16LGcpFXs%3D%3AE3sg0olJZpcJnEISYDtSflIn6I4TRzS642gWSohv124%3D”,“message”:“starting upgrade from 10.8.0.4 to 10.8.0.4”}
I’ve changed permissions for apps/ … I’ll inform you about the result.
Today, forced upgrade again.
Have you doubly installed apps, in both dirs apps and apps-external?
No installation for several weeks. I’ll check the server and let you know.
------------------------- common apps
activity
files_mediaviewer
files_pdfviewer
files_texteditor
market
With “common apps” you mean you have dupes of all these apps?
If so, I’d move the more recent version to the correct app-directory and then remove the older one.
files_mediaviewer, market → apps
activity, files_pdfviewer, files_texteditor → apps-external
But it’s still very strange, what triggers the update every Tuesday. I assume you don’t have some cron entries or so.
OK, I’ll try to fix the apps. There is running a system cron every 15 minutes.
occ system:cron
This is normal, shouldn’t trigger updates. You could also check
occ background:queue:status
Many thanks for your support. The server is running over 2 weeks without forced upgrade.
I’ll monitor the server for one more week and then close, if ok.
