I need to have some special files in owncloud WWW root directory. However, since version 10.x I get a complain about integrity check. This is a good thing, however, is there a way to somehow ``validate’’ own added files, so that the message isn’t shown anymore ?
Thank you for this information. Disabling doesn’t seem a good idea, indeed.
The reason is that I developed a monitoring tool which gets some information from host to know its status (debian package updates, etc.). And I made a very simple system based on a file generated in owncloud root directory. I could of course create another vhost with this information, but I liked the simplicity of my monitor which didn’t need too much configuration.
So, I was wondering if I could somehow add custom files and have them validated in owncloud.
Thank you very much. That was exactly what I was looking for. There is one file which is not easy to guess, so I assume I’m pretty safe even with this file being excluded.
I like to keep things simple as possible. I have multple machines to check and not only owncloud installations. So, my script monitors smtp, http(s), pop3/imap(s), mailqueues, debian update status, free space, etc. And for this I made very simple script which runs on each host to monitor which generates a file located on www root, so that I can access it remotely very easily.
I could write an app, but for now I do not have time for this
Well, I think its a matter of design. I would suggest, that your script is creating its datafile elsewhere, and finally upload it to an ownCloud folder via WebDav.
But of course, its up to you.
Then my script would need to identify if it’s running on an owncloud instance or another kind of server. You’re right that it is a question of design. From my point of view, a monitoring system as to be the simple as possible
