- I cannot login : I have the following message “precondition failed”. Is there a way to get a more detailed log of the client app ?
- I expect this client app to be able to connect to my account.
- Type in the URL (message “secure connection established”)/ user name / password
- Click on “connect”
- Displays /!\ Precondition failed
Can this problem be reproduced with the official owncloud server? No
(url: https://demo.owncloud.org, user: test, password: test)
Environment data
Android version: 6.0
Device model: Motorola E (2nd gen)
Stock or customized system: stock
ownCloud app version: 2.11.1
ownCloud server version: Unknown (this is a hosted solution)
i think this information is quite important. From what i know you could append a “status.php” like e.g.:
https://demo.owncloud.org/status.php
to see which version the connected ownCloud instance is running.
@demetre check the release post how to access the the debug logs from the settings page:
Thanks for your reply,
the json reply to status.php is the following:
{“installed”:true,“maintenance”:false,“needsDbUpgrade”:false,“version”:“16.0.1.1”,“versionstring”:“16.0.1”,“edition”:"",“productname”:“DediKam”}
As it seems, there was a migration to Nextcloud, which is probably the reason for this issue. I’ll try the nextcloud app…
Please consider this issue as closed since I was not aware of the server migration from owncloud to nextcloud. The nextcloud app is working fine.
