I got a notification of a new OC version 9.1.1 and did the following
- Go to Admin > Updater
- Open update
OC downloading latest update
Got an error message:
[GuzzleHttp\Exception\RequestException]
cURL error 60: SSL certificate problem: unable to get local issuer certificate
[GuzzleHttp\Ring\Exception\RingException]
cURL error 60: SSL certificate problem: unable to get local issuer certificate e
Operating system: Ubuntu 14.04.2
Web server: Apache 2
PHP version: 5.6.23
Updated from an older ownCloud or fresh install: Update
Using Let’s Encrypt SSL certificates for www.domain.com
OC located in www.domain.com/owncloud
As far as I can see, the owncloud.log doesn’t contain anything relevant. I specifically used tail -f and rerun the procedure above.
{"reqId":"SXHYdcXImheiIw+2KDna","remoteAddr":"192.168.1.1","app":"PHP","message":"Invalid argument supplied for foreach() at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/Authentication\/TwoFactorAuth\/Manager.php#112","level":3,"time":"2016-11-05 09:44:08","method":"GET","url":"\/o\/apps\/news\/","user":"adminuser"}
{"reqId":"SXHYdcXImheiIw+2KDna","remoteAddr":"192.168.1.1","app":"PHP","message":"Undefined index: two-factor-providers at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/Authentication\/TwoFactorAuth\/Manager.php#111","level":3,"time":"2016-11-05 09:44:08","method":"GET","url":"\/o\/apps\/news\/","user":"adminuser"}
{"reqId":"SXHYdcXImheiIw+2KDna","remoteAddr":"192.168.1.1","app":"PHP","message":"file_exists(): open_basedir restriction in effect. File(\/var\/www\/clients\/client1\/web3\/web\/o\/themes\/mytheme\/apps\/tasks\/img\/tasks.svg) is not within the allowed path(s): (\/var\/www\/clients\/client1\/web3\/web:\/var\/www\/clients\/client1\/web3\/private:\/var\/www\/clients\/client1\/web3\/tmp:\/var\/www\/domain.com\/web:\/srv\/www\/domain.com\/web:\/usr\/share\/php5:\/usr\/share\/php:\/tmp:\/usr\/share\/phpmyadmin:\/etc\/phpmyadmin:\/var\/lib\/phpmyadmin:\/usr\/share\/php:\/home\/user\/oc\/data:\/dev) at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/URLGenerator.php#158","level":3,"time":"2016-11-05 09:44:08","method":"GET","url":"\/o\/apps\/news\/","user":"adminuser"}
{"reqId":"SXHYdcXImheiIw+2KDna","remoteAddr":"192.168.1.1","app":"PHP","message":"file_exists(): open_basedir restriction in effect. File(\/var\/www\/clients\/client1\/web3\/web\/o\/themes\/mytheme\/apps\/tasks\/img\/tasks.svg) is not within the allowed path(s): (\/var\/www\/clients\/client1\/web3\/web:\/var\/www\/clients\/client1\/web3\/private:\/var\/www\/clients\/client1\/web3\/tmp:\/var\/www\/domain.com\/web:\/srv\/www\/domain.com\/web:\/usr\/share\/php5:\/usr\/share\/php:\/tmp:\/usr\/share\/phpmyadmin:\/etc\/phpmyadmin:\/var\/lib\/phpmyadmin:\/usr\/share\/php:\/home\/user\/oc\/data:\/dev) at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/URLGenerator.php#160","level":3,"time":"2016-11-05 09:44:08","method":"GET","url":"\/o\/apps\/news\/","user":"adminuser"}
{"reqId":"SXHYdcXImheiIw+2KDna","remoteAddr":"192.168.1.1","app":"PHP","message":"file_exists(): open_basedir restriction in effect. File(\/var\/www\/clients\/client1\/web3\/web\/o\/themes\/mytheme\/apps\/tasks\/img\/tasks.png) is not within the allowed path(s): (\/var\/www\/clients\/client1\/web3\/web:\/var\/www\/clients\/client1\/web3\/private:\/var\/www\/clients\/client1\/web3\/tmp:\/var\/www\/domain.com\/web:\/srv\/www\/domain.com\/web:\/usr\/share\/php5:\/usr\/share\/php:\/tmp:\/usr\/share\/phpmyadmin:\/etc\/phpmyadmin:\/var\/lib\/phpmyadmin:\/usr\/share\/php:\/home\/user\/oc\/data:\/dev) at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/URLGenerator.php#161","level":3,"time":"2016-11-05 09:44:08","method":"GET","url":"\/o\/apps\/news\/","user":"adminuser"}
{"reqId":"lgMFf8MF+lhcOBIvhyMB","remoteAddr":"192.168.1.1","app":"PHP","message":"Undefined index: two-factor-providers at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/Authentication\/TwoFactorAuth\/Manager.php#111","level":3,"time":"2016-11-05 09:44:13","method":"GET","url":"\/o\/apps\/updatenotification\/credentials","user":"adminuser"}
{"reqId":"lgMFf8MF+lhcOBIvhyMB","remoteAddr":"192.168.1.1","app":"PHP","message":"Invalid argument supplied for foreach() at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/Authentication\/TwoFactorAuth\/Manager.php#112","level":3,"time":"2016-11-05 09:44:13","method":"GET","url":"\/o\/apps\/updatenotification\/credentials","user":"adminuser"}
{"reqId":"WRppK2cKmDOsDNXaidT4","remoteAddr":"192.168.1.1","app":"PHP","message":"file_exists(): open_basedir restriction in effect. File(\/var\/www\/clients\/client1\/web3\/web\/o\/themes\/mytheme\/apps\/tasks\/img\/tasks.svg) is not within the allowed path(s): (\/var\/www\/clients\/client1\/web3\/web:\/var\/www\/clients\/client1\/web3\/private:\/var\/www\/clients\/client1\/web3\/tmp:\/var\/www\/domain.com\/web:\/srv\/www\/domain.com\/web:\/usr\/share\/php5:\/usr\/share\/php:\/tmp:\/usr\/share\/phpmyadmin:\/etc\/phpmyadmin:\/var\/lib\/phpmyadmin:\/usr\/share\/php:\/home\/user\/oc\/data:\/dev) at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/URLGenerator.php#158","level":3,"time":"2016-11-05 09:57:49","method":"GET","url":"\/o\/settings\/admin","user":"adminuser"}
{"reqId":"WRppK2cKmDOsDNXaidT4","remoteAddr":"192.168.1.1","app":"PHP","message":"file_exists(): open_basedir restriction in effect. File(\/var\/www\/clients\/client1\/web3\/web\/o\/themes\/mytheme\/apps\/tasks\/img\/tasks.svg) is not within the allowed path(s): (\/var\/www\/clients\/client1\/web3\/web:\/var\/www\/clients\/client1\/web3\/private:\/var\/www\/clients\/client1\/web3\/tmp:\/var\/www\/domain.com\/web:\/srv\/www\/domain.com\/web:\/usr\/share\/php5:\/usr\/share\/php:\/tmp:\/usr\/share\/phpmyadmin:\/etc\/phpmyadmin:\/var\/lib\/phpmyadmin:\/usr\/share\/php:\/home\/user\/oc\/data:\/dev) at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/URLGenerator.php#160","level":3,"time":"2016-11-05 09:57:49","method":"GET","url":"\/o\/settings\/admin","user":"adminuser"}
{"reqId":"WRppK2cKmDOsDNXaidT4","remoteAddr":"192.168.1.1","app":"PHP","message":"file_exists(): open_basedir restriction in effect. File(\/var\/www\/clients\/client1\/web3\/web\/o\/themes\/mytheme\/apps\/tasks\/img\/tasks.png) is not within the allowed path(s): (\/var\/www\/clients\/client1\/web3\/web:\/var\/www\/clients\/client1\/web3\/private:\/var\/www\/clients\/client1\/web3\/tmp:\/var\/www\/domain.com\/web:\/srv\/www\/domain.com\/web:\/usr\/share\/php5:\/usr\/share\/php:\/tmp:\/usr\/share\/phpmyadmin:\/etc\/phpmyadmin:\/var\/lib\/phpmyadmin:\/usr\/share\/php:\/home\/user\/oc\/data:\/dev) at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/URLGenerator.php#161","level":3,"time":"2016-11-05 09:57:49","method":"GET","url":"\/o\/settings\/admin","user":"adminuser"}
{"reqId":"9EAR7g2CP9d3EVK24Gzh","remoteAddr":"192.168.1.1","app":"PHP","message":"Undefined index: two-factor-providers at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/Authentication\/TwoFactorAuth\/Manager.php#111","level":3,"time":"2016-11-05 09:57:50","method":"GET","url":"\/o\/avatar\/adminuser\/32","user":"adminuser"}
{"reqId":"9EAR7g2CP9d3EVK24Gzh","remoteAddr":"192.168.1.1","app":"PHP","message":"Invalid argument supplied for foreach() at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/Authentication\/TwoFactorAuth\/Manager.php#112","level":3,"time":"2016-11-05 09:57:50","method":"GET","url":"\/o\/avatar\/adminuser\/32","user":"adminuser"}
{"reqId":"I9KBpMA\/LETTDycIfGiW","remoteAddr":"192.168.1.1","app":"PHP","message":"Undefined index: two-factor-providers at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/Authentication\/TwoFactorAuth\/Manager.php#111","level":3,"time":"2016-11-05 09:57:52","method":"GET","url":"\/o\/apps\/theme_switcher\/settings","user":"adminuser"}
{"reqId":"I9KBpMA\/LETTDycIfGiW","remoteAddr":"192.168.1.1","app":"PHP","message":"Invalid argument supplied for foreach() at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/Authentication\/TwoFactorAuth\/Manager.php#112","level":3,"time":"2016-11-05 09:57:52","method":"GET","url":"\/o\/apps\/theme_switcher\/settings","user":"adminuser"}
{"reqId":"tPaGGEfK+rQSddU69vQE","remoteAddr":"192.168.1.1","app":"PHP","message":"Undefined index: two-factor-providers at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/Authentication\/TwoFactorAuth\/Manager.php#111","level":3,"time":"2016-11-05 09:57:54","method":"GET","url":"\/o\/apps\/news\/","user":"adminuser"}
{"reqId":"tPaGGEfK+rQSddU69vQE","remoteAddr":"192.168.1.1","app":"PHP","message":"Invalid argument supplied for foreach() at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/Authentication\/TwoFactorAuth\/Manager.php#112","level":3,"time":"2016-11-05 09:57:54","method":"GET","url":"\/o\/apps\/news\/","user":"adminuser"}
{"reqId":"tPaGGEfK+rQSddU69vQE","remoteAddr":"192.168.1.1","app":"PHP","message":"file_exists(): open_basedir restriction in effect. File(\/var\/www\/clients\/client1\/web3\/web\/o\/themes\/mytheme\/apps\/tasks\/img\/tasks.svg) is not within the allowed path(s): (\/var\/www\/clients\/client1\/web3\/web:\/var\/www\/clients\/client1\/web3\/private:\/var\/www\/clients\/client1\/web3\/tmp:\/var\/www\/domain.com\/web:\/srv\/www\/domain.com\/web:\/usr\/share\/php5:\/usr\/share\/php:\/tmp:\/usr\/share\/phpmyadmin:\/etc\/phpmyadmin:\/var\/lib\/phpmyadmin:\/usr\/share\/php:\/home\/user\/oc\/data:\/dev) at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/URLGenerator.php#158","level":3,"time":"2016-11-05 09:57:54","method":"GET","url":"\/o\/apps\/news\/","user":"adminuser"}
{"reqId":"tPaGGEfK+rQSddU69vQE","remoteAddr":"192.168.1.1","app":"PHP","message":"file_exists(): open_basedir restriction in effect. File(\/var\/www\/clients\/client1\/web3\/web\/o\/themes\/mytheme\/apps\/tasks\/img\/tasks.svg) is not within the allowed path(s): (\/var\/www\/clients\/client1\/web3\/web:\/var\/www\/clients\/client1\/web3\/private:\/var\/www\/clients\/client1\/web3\/tmp:\/var\/www\/domain.com\/web:\/srv\/www\/domain.com\/web:\/usr\/share\/php5:\/usr\/share\/php:\/tmp:\/usr\/share\/phpmyadmin:\/etc\/phpmyadmin:\/var\/lib\/phpmyadmin:\/usr\/share\/php:\/home\/user\/oc\/data:\/dev) at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/URLGenerator.php#160","level":3,"time":"2016-11-05 09:57:54","method":"GET","url":"\/o\/apps\/news\/","user":"adminuser"}
{"reqId":"tPaGGEfK+rQSddU69vQE","remoteAddr":"192.168.1.1","app":"PHP","message":"file_exists(): open_basedir restriction in effect. File(\/var\/www\/clients\/client1\/web3\/web\/o\/themes\/mytheme\/apps\/tasks\/img\/tasks.png) is not within the allowed path(s): (\/var\/www\/clients\/client1\/web3\/web:\/var\/www\/clients\/client1\/web3\/private:\/var\/www\/clients\/client1\/web3\/tmp:\/var\/www\/domain.com\/web:\/srv\/www\/domain.com\/web:\/usr\/share\/php5:\/usr\/share\/php:\/tmp:\/usr\/share\/phpmyadmin:\/etc\/phpmyadmin:\/var\/lib\/phpmyadmin:\/usr\/share\/php:\/home\/user\/oc\/data:\/dev) at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/URLGenerator.php#161","level":3,"time":"2016-11-05 09:57:54","method":"GET","url":"\/o\/apps\/news\/","user":"adminuser"}
{"reqId":"BnuAluk4Xchm+Lb+LPPA","remoteAddr":"192.168.1.1","app":"PHP","message":"Undefined index: two-factor-providers at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/Authentication\/TwoFactorAuth\/Manager.php#111","level":3,"time":"2016-11-05 09:57:54","method":"GET","url":"\/o\/settings\/ajax\/checksetup","user":"adminuser"}
{"reqId":"BnuAluk4Xchm+Lb+LPPA","remoteAddr":"192.168.1.1","app":"PHP","message":"Invalid argument supplied for foreach() at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/Authentication\/TwoFactorAuth\/Manager.php#112","level":3,"time":"2016-11-05 09:57:54","method":"GET","url":"\/o\/settings\/ajax\/checksetup","user":"adminuser"}
{"reqId":"CfqJywBCcHZ361qGNDsH","remoteAddr":"192.168.1.1","app":"PHP","message":"Undefined index: two-factor-providers at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/Authentication\/TwoFactorAuth\/Manager.php#111","level":3,"time":"2016-11-05 09:57:59","method":"GET","url":"\/o\/apps\/updatenotification\/credentials","user":"adminuser"}
{"reqId":"CfqJywBCcHZ361qGNDsH","remoteAddr":"192.168.1.1","app":"PHP","message":"Invalid argument supplied for foreach() at \/var\/www\/clients\/client1\/web3\/web\/o\/lib\/private\/Authentication\/TwoFactorAuth\/Manager.php#112","level":3,"time":"2016-11-05 09:57:59","method":"GET","url":"\/o\/apps\/updatenotification\/credentials","user":"adminuser"}
Integrity status for oC9+
