Hey guys,
i configured all right to the step where i open the link to https://mydomain.com/owncloud to finish the setup of owncloud.
The problem is, i cant finish it cause i get this error at the top of the box where i type the username and password in when i try to finish the installation. Error while trying to create admin user: An exception occurred while executing ‘ALTER TABLE oc_calendarsubscriptions CHANGE lastmodified lastmodified INT UNSIGNED DEFAULT NULL NOT NULL’: SQLSTATE[42000]: Syntax error or access violation: 1067 Invalid default value for ‘lastmodified’
I dont know what i have to do now, to resolve it. Maybe someone of you can help me.
I’m using Ubuntu 16.04.3 LTS and nginx webserver / mariaDB.
Hehe that sucks i need that for my graduation project
Yes its a fresh install.
Can i try to install v9 as workaround and upgrade later or should i wait ?
I can try a reinstall tomorrow and writing down the steps.
When i get again the error or the reinstall fixed it for me - i let you know.
Thanks dmitry.
Ok i did the same steps with 10.0.3 like i did with 9.0.2 and i get the same error from my opening post again. Seems its a bug on this version. I try now 9.1.6 again. ^^
