Problems Syncing Very Large Files
  1. Install ownCloud Link
  2. Setup HTTPS for domain name Link
  3. Create mySQL database
  4. Setup Redis caching Link
  5. Turn on encryption inside owncloud settings
Expected behavior
Files up to the maximum file size limit stated (10 GB) should upload without a problem.
Actual behavior
Extremely large files fail to upload whether it be from a desktop client or the web app. My test file is typically a 4 GB operating system iso.
I have gone through as many troubleshooting methods as possible. I’ve made a post about this before here Link. I wiped my server entirely, reinstalled ownCloud, and made no changes to it and it still failed to upload large files over the internet. If I am on my local network it works fine. At this point I’m out of ideas with what to do.
Operating system: Ubuntu Server 16.04.02 LTS
Web server: Apache2
PHP version: 7.0.15
ownCloud version: 9.1.5
Where did you install ownCloud from: Command line (see link above)
Signing status (ownCloud 9.0 and above): Not sure what this is asking
Results below
https://gist.github.com/JosephBateh/77658a8ede0fbcbd9bc0889a69ec9514
Enabled:
  - activity: 2.3.2
  - comments: 0.3.0
  - configreport: 0.1.1
  - dav: 0.2.7
  - encryption: 1.3.0
  - federatedfilesharing: 0.3.0
  - federation: 0.1.0
  - files: 1.5.1
  - files_pdfviewer: 0.8.1
  - files_sharing: 0.10.0
  - files_texteditor: 2.1
  - files_trashbin: 0.9.0
  - files_versions: 1.3.0
  - files_videoplayer: 0.9.8
  - firstrunwizard: 1.1
  - gallery: 15.0.0
  - notifications: 0.3.0
  - provisioning_api: 0.5.0
  - systemtags: 0.3.0
  - templateeditor: 0.1
  - updatenotification: 0.2.1
Disabled:
  - external
  - files_antivirus
  - files_external
  - user_external
  - user_ldap
Are you using external storage, if yes which one: none
Are you using encryption: yes
*Are you using an external user-backend, if yes which one: *Don’t think so?
Browser: Chrome, Safari
Operating system: Windows 10, MacOS
https://gist.github.com/JosephBateh/08a5f5d53a0ccbd83c7a58185443b3c4
When on admin page: GET https://neon.josephbateh.com/owncloud/data/htaccesstest.txt?t=1494643726715 403 (Forbidden)
If there is a difference between “over the internet” and “local network” then just one of the many timeouts in the webserver, PHP or similar are kicking in.
Unfortunately there is “single” solution for this possible so watching logfiles like the one of your webserver, the PHP error log or the data/owncloud.org might help you debugging this issue.
I’ve been monitoring that, the problem is I don’t know how to fix them. I have changed the timeout values with no success. If you could recommend settings to change for the problem, I would really appreciate it. Maybe I missed one of the possible options.
All known limits which might be required to raise are documented at the following resources [1] or [2]. Maybe you have missed one listed there.
[1]
[2]
I think the problem was the router I was using. It was an Apple Time capsule router. I’ve since switched to Google Wifi (connecting using an ethernet cable) and the problem has disappeared.
