Hello all,
i currently experimenting with OwnCloud and collabora CODE.
initially i just installed and tested with the quick tryout
that is basically:
docker run -d -p 80:80 owncloud
docker run -t -d -p 9980:9980 -e "extra_params=--o:ssl.enable=false" collabora/code
i got this to work and happily tested things
as the page warns this is not meant as production system.
so what is the best way to move forward from this?
i am new to the docker world -
so maybe i will have to learn a bunch of things regarding this
things i already found
but iam unsure if / what combination is the recommend way…
hope someone can give me tips or links to tutorials & or background information regarding this
sunny greetings
stefan
target ‘requirements’
- strato VServer
- Ubuntu 18.04 LTS 64bit
- CPU vCores: 4
- RAM 8 GB
- 2-5 user
I have used nginx-proxy and caddy for this, but you’re linking to traefik in your post.
Anyhow they are all reverse proxies it should basically work the same: put it in front of your owncloud as well as the collabora server.
Then all you have to configure in ownCloud is that your collabora endpoint is traefik, which will then forward you to collabora. And in collabora you will have to adjust the config to have traefik as the reverse proxy that is terminating the SSL connection.
The ownCloud and collabora docker containers don’t even need to have their ports publicly exposed, traefik can do the forwarding to them.
However I don’t have any more detailed instructions so you will have to experiment around a little. Would be cool if you could document your process here how you set it up.
Thanks @eneubauer for your respons.
i have experimented a little more and have an 99% working system:
What does not work?
new user email link → the initial set password field on this site uses http and therefore breaks…
i found this thread but it only points to the Traefik docker tutorial.
and currently i have no motivation left to learn and experiment with something new again
fixed:
add
OWNCLOUD_OVERWRITE_PROTOCOL=HTTPS
to your owncloud-docker-server/docker-compose.yml file in the environment: section.
my apache VirtualHost configs:
cloud.conf
<VirtualHost *:80>
ServerName cloud.example.de
Options -Indexes
RewriteEngine on
RewriteCond %{SERVER_NAME} =cloud.example.de
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
cloud-le-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost *:443>
ServerName cloud.example.de:443
Options -Indexes
## letsencrypt
SSLCertificateFile /etc/letsencrypt/live/cloud.example.de/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/cloud.example.de/privkey.pem
Include /etc/letsencrypt/options-ssl-apache.conf
# Encoded slashes need to be allowed
AllowEncodedSlashes NoDecode
# Container uses a unique non-signed certificate
# SSLProxyEngine On
# SSLProxyVerify None
# SSLProxyCheckPeerCN Off
# SSLProxyCheckPeerName Off
# keep the host
ProxyPreserveHost On
# redirect to owncloud
ProxyPass / http://127.0.0.1:8080/ retry=0
ProxyPassReverse / http://127.0.0.1:8080/
</VirtualHost>
</IfModule>
lool.conf
<VirtualHost *:80>
ServerName lool.example.de
Options -Indexes
RewriteEngine on
RewriteCond %{SERVER_NAME} =lool.example.de
</VirtualHost>
lool-le-ssl.conf
<VirtualHost *:443>
ServerName lool.example.de:443
Options -Indexes
# letsencrypt
SSLCertificateFile /etc/letsencrypt/live/lool.example.de/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/lool.example.de/privkey.pem
SSLProxyEngine On
SSLProxyVerify None
# keep the host
# basic run check
# ProxyPass / http://127.0.0.1:9980/ retry=0
# ProxyPassReverse / http://127.0.0.1:9980/
# static html, js, images, etc. served from loolwsd
# loleaflet is the client part of Collabora Online
ProxyPass /loleaflet http://127.0.0.1:9980/loleaflet retry=0
ProxyPassReverse /loleaflet http://127.0.0.1:9980/loleaflet
# WOPI discovery URL
ProxyPass /hosting/discovery http://127.0.0.1:9980/hosting/discovery retry=0
ProxyPassReverse /hosting/discovery http://127.0.0.1:9980/hosting/discovery
# Capabilities
ProxyPass /hosting/capabilities http://127.0.0.1:9980/hosting/capabilities retry=0
ProxyPassReverse /hosting/capabilities http://127.0.0.1:9980/hosting/capabilities
# Main websocket
ProxyPassMatch "/lool/(.*)/ws$" ws://127.0.0.1:9980/lool/$1/ws nocanon
# Admin Console websocket
ProxyPass /lool/adminws ws://127.0.0.1:9980/lool/adminws
# Download as, Fullscreen presentation and Image upload operations
ProxyPass /lool http://127.0.0.1:9980/lool
ProxyPassReverse /lool http://127.0.0.1:9980/lool
</VirtualHost>
</IfModule>
[edit: added virtual host configs]
[edit: fixed http passwort set error]
I would recommend to just redirect all traffic from port 80/http to port 443/https directly in your apache reverse proxy configuration.
I don’t really see how this breaks, perhaps you get some error messages in the logs you could post here?
i added the apache virtuahosts configs.
and i think they just do this
browser console error:
Content Security Policy: The page’s settings blocked the loading of a resource at inline (“script-src”). 2 content-script.js:40:65
10:01:08.415 JQMIGRATE: Migrate is installed, version 1.4.0 jquery-migrate.min.js:2:552
10:01:09.739 Password fields present in a form with an insecure (http://) form action. This is a security risk that allows user login credentials to be stolen.
Test1
10:01:35.237 Content Security Policy: The page’s settings blocked the loading of a resource at http://cloud.example.de/setpassword/51nxnxnxnxnxnxnxnxnxn/Test1 (“connect-src”). jquery.min.js:4:14952
10:01:35.237
SyntaxError: JSON.parse: unexpected character at line 1 column 1 of the JSON data
setpassword.js:34:27
10:01:35.638 Source map error: Error: JSON.parse: unexpected character at line 1 column 1 of the JSON data
Resource URL: https://cloud.example.de/core/vendor/jquery/dist/jquery.min.js?v=51nxnxnxnxnxnxnxnxnxn
Source Map URL: jquery.min.map
in the owncloud logs i did not find any hint on this at all.
i think i have to tell owncloud in the docker image somehow that it is running behind a reverse proxy…
ok now as far as i have tested it seems to work
added in the owncloud-docker-server/docker-compose.yml file seems to do the trick.
thanks for your tips.
sunny greetings
stefan
