Stuck in maintenance mode due to apps not upgradeable
#1
Hi there everyone!
Tried to update my OC installation this morning and it seems every app I ever installed is incompatible with the latest version. Could I ask how I would go about disabling or uninstalling these so I can get my install working again?
This is the part I don’t understand:
 disable them with: occ app:disable afterlogic occ app:disable audioplayer occ app:disable calendar occ app:disable contacts occ app:disable files_clipboard occ app:disable files_pdfviewer occ app:disable files_texteditor occ app:disable gallery occ app:disable ownbackup occ app:disable rainloop occ app:disable security occ app:disable templateeditor
This is an installation that was originally installed via the web script on a Deb 9 machine.
        Repair warning: You have incompatible or missing apps enabled that could not be found or updated via the marketplace.
        Repair warning: Please install or update the following apps manually or disable them with: occ app:disable afterlogic occ app:disable audioplayer occ app:disable calendar occ app:disable contacts occ app:disable files_clipboard occ app:disable files_pdfviewer occ app:disable files_texteditor occ app:disable gallery occ app:disable ownbackup occ app:disable rainloop occ app:disable security occ app:disable templateeditor
        Repair warning: For manually updating, see https://doc.owncloud.org/server/10.0/go.php?to=admin-marketplace-apps
Detailed logs:
Preparing update
Set log level to debug
Turned on maintenance mode
Upgrade impossoble
Upgrade to owncloud-10.0.9 fails
#2
Hey, this looks like the same another user is seeing with all apps in the following thread:
