Good morning, I have my owncloud installation at this link: Domena markinfspzpq.nazwa.pl jest utrzymywana na serwerach nazwa.pl it was all right and now when I try to login is a message that login is taking too long to try again. How to deal with this?
I have the same problem. How do you fixed it?
with the following search (you probably have used something similar to find this thread):
https://central.owncloud.org/search?q=%22you%20took%20too%20long%20to%20login%22
i found a few other threads where others have reported some observations:
With the following two a reinstall of the packages “worked”: You took too long to login, please try again now, Stuck on WEB UI Login screen
Here a “http” vs. “https” have been observed which makes a difference: Login fails “You took too long to login, please try again now”
With this an update of PHP worked: Cannot login to Owncloud X after a fresh install
This seems to be unanswered but i just want to add a reference to it anyway: Problem with login
Dear tom42,
yes, I found all of them. I installed owncloud new, nothing changed. I installed new PHP7.2, nothing changed. I use https, nothing changed. The only thing I can do is to format my raspberry pi but I want to avoid this solution. For my login window the user and password is irrelevant. Indepent on the input i receive the same message.
Hey, then i think its the best if you keep an eye on the following thread to see if some one finds a solution for this:
