ownCloud RCs for maintenance releases are out, please help testing!
Here are the links:
Thanks for helping out Folks!
Not sure if this motivates more people to test. You could add a changelog or even mention what to test specifically (e.g. federated-sharing in combination with external storage). If you don’t have much time, you don’t want to look through all pull requests and figure out what’s worth testing (sometimes it’s hard to guess for non-experts).
I absolutely agree, maybe @RealRancor and / or @PVince81 could help me out on this.
Ok, here’s a changelog for the RCs:
9.1.1
  • Core: Remove OCS response body for HTTP status 204 and 304 which disturbed some firewalls - core/#25835
  • Core: Map Oracle driver options to params - core/#23938
  • Core: Log cron job class name for easier troubleshooting - core/#25743
  • Core: Skip version and trash expiry for users that never logged in - core/#25741
  • Core: Added white download icons for apps to use - core/#23891
  • Core: Fix warning about undefined offset in LoginController - core/#25714
  • Core: Fix warning about undefined two factor providers - core/#25606
  • Core: Load app before executing its repair steps - core/#25674
  • Core: Fix “defaultapp” setting - core/#25562
  • Core: Fix issue when opening some file app links received in share emails - core/#25200
  • DAV: Faster classification migration in CalDAV - core/#25638
  • DAV: Error message about forbidden password login is now logged in debug level - core/#25486
  • DAV: Return “data-fingerprint” property on any file related element - core/#25482
  • DAV: Fix missing properties in CalDAV subscriptions - core/#24469
  • Sharing: Fixed wrong insufficient storage error - core/#25582
  • Sharing: Prevent shared storage recursions to avoid memory issues and crashes - core/#25557
  • Sharing: Group received shares which have same source and target - core/#25113
  • Sharing: Fix sharing over API when dealing with trailing slashes - core/#25464
  • Sharing: Fix public upload issue with quota in some scenarios - core/#24751
  • Sharing: Fix issue where videos did not play from share links with PHP 7 - core/#25483
  • Sharing: Fix BadMethodCallException in cron or scanner - core/#25506
  • Encryption: OCC command for decryption now doesn’t decrypt received shares - core/#25599
  • Files_external: Removed reference magic to avoid potential infinite loops - core/#25844
  • Files_external: Added conditional trace logging for debugging SMB on productive systems - core/#25758
  • Files_external: Fix config database issue when using Oracle - core/#25764
  • Files_external: SMB subfolders with read-only attribute are now writeable in OC to match spec - core/#24608
  • Files_external: Fix “save in session” mode when using Webdav without cookies/session - core/#25511
  • Files_external: Respect theme for external folder icon - core/#25461
  • Files_external: Disable NFD encoding wrapper that was enabled by mistake for local storages - core/#25819
  • LDAP: Fix login issue when dealing with display name of deleted users - core/#23248
  • LDAP: Prevent triggering email change events at login time for unchanged email - core/#25553
  • Provisoning API: Fixed issue where subadmins could not change group memberships - core/#25496
  • Activity: Fix owner name processing for received federated shares - core/#24938
  • Antivirus: Fix incorrect report of file size - files_antivirus/#120
9.0.5
  • Core: Sanitize more data in config report - core/#23728
  • DAV: Added quota plugin to new DAV files endpoint - core/#25646
  • Sharing: Fix path sent by shared storage hooks, could affect some apps like gallery - core/#23620
8.2.8
  • LDAP: Fix user cleanup tool deletion detection accuracy - core/#25338
  • Updater: Fix “unable to extract package Array” - updater/#134
8.1.10
  • Updater: Properly copy ca-bundle.crt when updating to 8.1.x - updater/#164
8.0.15
Most important to test for 9.0.5:
And for 9.1.1:
The testing phase was extended:
