Blogpost about upgrading: https://owncloud.org/blog/introducing-owncloud-x/
General changes in this release: Changelog - ownCloud
Please read those links carefully!!!
If you find another issue which should be in this FAQ, please write me a DM with a link to the problem/solution.
Common issues
Updates between multiple major versions and downgrades are unsupported.
Please see:
On every major upgrade it is recommended to do a full upgrade by deleting all files and folders within your installation directory except /data/ and /config/ and then extract the new code into this installation directory. How to do a full upgrade can be found at the documentation: ownCloud Documentation Overview :: Documentation for ownCloud (A Kiteworks Company)
There are some issues with the web updater. If you encounter them, you can look here for the patch: Patches for known update issues from versions 10.0.0-10.0.2 (updated on June, 13)
Guest accounts and custom groups are available via the marketplace, you have to look there.
##Known Bugs
Adding local external storage is disabled by default, for security reasons.
Can't add local external storage, option not available
There is a workaround in the central thread; you should only enable it if sysadmin and owncloud admin are the same person on you system. -
Copy-pasting a link for sharing doesn’t work with the Safari browser.
Copying public links is not possible using safari. · Issue #28105 · owncloud/core · GitHub
Already fixed Bugs
Local External Storage missing, not able to assign folders to single users.
Owncloud 10.0.0 Local external storage missing
Fix: was turned off due to security reasons, you can turn it on in the config.php. -
Upgrade doesn’t work because Calendar app can’t be disabled.
Upgradeproblem auf 10.0.0
Fix: turn it off before the update or anytime withocc app:disable calendar -
With maintenance mode on and client 2.3.x, sometimes files got deleted on clientside.
[10.0.0] The ownCloud desktop client is temporarily removing most of my files locally when server gets into maintenance mode · Issue #5738 · owncloud/client · GitHub
Fix is available via github. -
When upgrading to 10.0.0, sometimes the calendar app broke.
missing databasefield "publicuri" in oc_dav_shares after upgrade to 10.0.0 (stable) from 9.1.5 · Issue #27754 · owncloud/core · GitHub
The problem is solved with 10.0.1. -
The “old” CalDAV and CardDAV URLs have not been working and clients which used them stopped working: caldav/carddav syncing problem after upgrade to 10.0.0 · Issue #27778 · owncloud/core · GitHub
This is fixed with 10.0.1.
